badassbanshee479 Posted October 16, 2007 Report Share Posted October 16, 2007 did ya happen to check and see if the drill bit was bigger than the dump tube? (where the needle passes through. Cause if the drill bit is not smaller than the dump tube and you drill the main bigger, you will not be getting anymore fuel because the dump tube is now the restriction not the main jet. Take the carb off and pull the float, get your self a drill index and see what size fits in the dump tube and get back to me. Quote Link to comment Share on other sites More sharing options...
