Cheetha super cub
patarol
Yes...Are...
You need to get a dunable override tranny.
Are you getting a longer swing arm and your shock stiffened up/revalved as well?
Yes gona get the CPI pipes. Wont the stock tranny work? Pleaswe xplain the overide to me! Wat piston to runn, see you all say wiseco pro lite, som recomend blaster pistons why? have
Nope no carbs, there kit comes with : welding of cases, DM top end with head, billet crank, trench cases for stroke, labor, billet clutch basket, straight cut gears, hd clutch, lockup clutch, quickchange cover polished, pancake clutch bearing, vforce reeds, intake manifolds, gaskets, and seals
Holy Crap so you still need Overide another + or - 375 and carbs + or - 350.Damn Ill stick with my 4mm Cub for 3600 ready to bolt on with head carbs overide lockup and Ported.Or 3750 polished.
I'd get the regular cub....with EXTENSIVE porting, the super cub might make a HP or two more....out of the box with clean up ports, the 68 runs better, believe it or not.
DM is the ticket...but that's some coin there, and now you're talking new pipes, intakes, head...and a LOT of case work.
Word. :thumbsup:
DMs are the Cylinders they were saying earlier in this post that were 78mm bore.They are very expensive and should be left for drag only bikes imo.Are you in any type of budget?
Not realy, got all winter, but gues i`l be spending 2-3000$ on the engine. What pistons to run in the cub?
My 4mm Cub is costing me 3600.I already have pipes and vforces.But thats with lockup and overide transmission.And drag ported.But remember you get some money back selling your stock stuff
Yes, gona keep my stock stuf, it already cost my 1500$ keep as backup. The cheetha is nicasil coted so if i mes it up its a new to buy?
