both tires are flat wtf.
pweezy42
both front tires keep going flat i fill them up and sant find any leaks. i can ride all day but bye mornin they r flat. WTF any suggestions
Hell those tires didnt go flat, Your back tires there just swelled right up on ya!....LOL... if you cant find any leaks... then heck i have no clue... have u checked the valve stem?.. it might be leaking through the core around the cap..???
not yet 2mrw when i go 2 the garage i will have to .i heard that gfreen slime stuff works good anybody use that stuff?
I dont put it in tires, makes a mess when you got to de-bead them or swap them. The tire and rim should seal up on its own, if it doesn't you should not mask the leak with green slime.
i will have to try the garbage can method, like i said the air will last for 12 hrs but in the mornin they r almost flat did the soapy water test but nothin that way
slime works for the bead but your have to start out with a clean bead on the first place. i run it in my front tires as i always had problems with sand getting in the beads from turning sharp and slow in thick sand. i dont have near the problems i did. it does take a bit of creativity to keep from making a mess when i do have to clean out the beads.
Edited by Coupelx
My idea still stands... if you have checked the beads and nothing seems to be leaking... check into the valve stem/core ... it could possibly be leaking from there if everything else checks out.. then again.. tires can do some weird things...no clue.. fill us in when ya find the culprut
well after a long wet ride :down: i found the culprit on one tire 3 pin size holes in diff. locations :down: left tire is still a mystery :shrug:
yea, even if you do the soapy water test, it is still possible for holes to be undetected. Same way with car tires, a tiny pinhole with pressure behind it won't cause the soap to bubble up, but it will push it out of the way.
