paddles?
socal909
How long of an arm are you running.
I have a patriot racing 400cc drag port 4 mill. I have a stock arm and Dan from patiot racing recomend running skat trak 20x10x10 9 paddle extreems. He said if I was going to be running a +6 arm then 21x10x8 10 paddle extreems would be a good choice.
usualy dune bikes run a 20 inch tire with a 10 inch rim. drag bikes usualy run a 22 inch tire with an 8 inch rim so it balloons like a drag tire when your hard on the throttle. bigger dune bikes can get away with running a 22 inch tire which will get you more clearance at the rear sprocket because they have the power to turn them. basicly the more power you have will dictate what size tire/rim combo you run. usualy you start with 20/10/10's and work your way up on number of paddles then goto bigger tires then smaller rims...
