Best place to start ?
202banshee
Been trying to get this clutch right for a week now. When I had it apart to adjust it I didnt notice any grooves in basket. The clutches are suppose to be new. The guy I got it from just had in a shop to have them replaced. I did notice that when you pull the clutch the pressure plate comes outward unevenly. Also the clutch lever is pretty stiff. (he claims it always has been and he lubed it real good one time and it eased up) .. Now that I adjusted it drops in gear ok when cold but when you get to riding and heat it up it starts to drag pretty bad. Wont even stay running after warm when in gear. Clutch lever seems to stiffen also. I have seen some on ebay with the grooves in the basket but mine had none. Just wanting to spend as little as possible cause when I get it right it is sold and the more I put in the more I will have to get back out LOL THANKS
Sounds like you may need inner/outer hubs (pressure plates) or your clutch is shot. Also check your freeplay in the clutch lever and is it an easy pull? Some easy pulls dont have enough throw to disengage correctly.
  • 2 weeks later...
Installed new fac clutch lever and cable. Made a world of difference. So much easier to pull. And dont seem to drag anymore.
I got 2 questions though
#1 It's still is a b!tch sometimes trying to get nuetral. Any ideas ??
#2 Also changed my oil and this time I ran a synthetic 50W that we use in the tranny's at work. (med -heavy trucks) What do you guys think ???
#1 The banshee is almost always a bitch to get in neutral.Most people modify the shift star for smoother shifting and it makes it easier to get neutral.
#2 Dont know about a 50w.I run bel ray 80w.
