spike Posted October 10, 2007 Report Share Posted October 10, 2007 I just got a set of works dual rates with remote rezzie's, I think that the nitrogen bottles are empty, when i try to take the pressure in them there nothing, am I supposed to get a reading out of these? if yes what is it? I can fill them up at work as we use nitrogen in the aircrafts tires. but i'm not sure how much to put in. thanks. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted October 10, 2007 Report Share Posted October 10, 2007 it depends on what they are setup for but i want to say its like 600 psi. if you use a tire gauge type thing to to test it you will loose almost all of the pressure in no time. its a quick sss and its gone... call works and ask them they would be able to tell you for sure Quote Link to comment Share on other sites More sharing options...
Banshee 79 Posted October 10, 2007 Report Share Posted October 10, 2007 I just got a set of works dual rates with remote rezzie's, I think that the nitrogen bottles are empty, when i try to take the pressure in them there nothing, am I supposed to get a reading out of these? if yes what is it? I can fill them up at work as we use nitrogen in the aircrafts tires. but i'm not sure how much to put in.thanks. Works,Custom Axis, and PEP all recommend 200 pounds. Elka and Ohlins recommend 150 pounds Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted October 10, 2007 Report Share Posted October 10, 2007 Works,Custom Axis, and PEP all recommend 200 pounds. Elka and Ohlins recommend 150 pounds you know what 200 does ring a bell. this sound about right..... Quote Link to comment Share on other sites More sharing options...
spike Posted October 10, 2007 Author Report Share Posted October 10, 2007 damn!! I was expecting something in the 50ish range, anyway, any tips on refurbishing shocks beside filling them with nitrogen? im going to take em apart and sandblast-powdercoat the springs and polish the shit out off them. I they where setup for a 220 pound riders on stock a arms will they work alright for me +3 arms 180 lbs? or a revalve is a must. im new to this shock business and there is alot of thing im not sure. :ermm: Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted October 10, 2007 Report Share Posted October 10, 2007 damn!! I was expecting something in the 50ish range, anyway, any tips on refurbishing shocks beside filling them with nitrogen? im going to take em apart and sandblast-powdercoat the springs and polish the shit out off them. I they where setup for a 220 pound riders on stock a arms will they work alright for me +3 arms 180 lbs? or a revalve is a must. im new to this shock business and there is alot of thing im not sure. :ermm: there is more to the valveing then the wieght its all about return rates and all that, id say bit the bullet and have it done right for your weight. they will change out all the seals and put new oil in there as well.im probly going to have to do the same thing on my rear marvin shaw i just got, but its alot cheaper then an elka or works shock Quote Link to comment Share on other sites More sharing options...
