first ride
welcome to the hobby..
first day not 2 bad. put the new tires on and in 45 mins plugged 2 holes on the inside left rear tire..(good thing i brought plugs and some fix a flat) 1hr and 45 mins later going up a nice hill at the top my chain decides to pop off and get jammed in the sproket but after a lil fight w/the chain i was back up and runnin all in all it was a good day .............oh and bye the way boy does she scream!!!!!!!!(any one help me out w/tightenin the chain) :evil:
you gotta play with the axle carrier...
i really dono how to explane it ... if i did you would get confused...
anyone wanna take this one :)
there are 2 carrier bolts, loosen them both the top just enough to move the carrier with alittle force, then you have on the bottom bolt 2 tear drop shaped thingies with a lock nut and bolt. I dont remember which way to go to tighten/loosen, but thats how you do it. I put about a 1/2" play sitting on it, so its not to tight eating a jump, and not to loose off the ground.
