Rear Suspension setup?
magiksc
Sorry if this has been addressed elsewhere on here but i can not seem to find any information on the best rearend suspension setup for a banshee. What are you guys doing? I'm thinking of putting 450 arms and shocks on my frontend or wicked long travel arms. But really have no idea what options I have for the rearend, I'm on a budget so a little help from you guys would be greatly appreciated.
if your rich or rob your local corner store this is the basiclly the best rear shock AND new linkage set up you can bolt up.
http://cgi.ebay.ca/Elka-Rear-Shock-Long-Tr...1QQcmdZViewItem
i say send your shock to someone like TCS, get it revalved and have a new spring put on it for your weight, i think they also do dual rate spring packages for the rear shock too.
and in my opinion those 450 front ends are too low for trail riding, or jumping, they lower the bike down alot and dont leave much room for ground clearance or suspension travel
:confused:
450 arms are good for normal +2+1
my stock rear is fine for the time being...
im 197 pounds...went to the doctors office last week lol
Is this true that the yfz kits lower the front end? If so how much?
next question is would the dual rate coil set up from tcs be worth it? It seems that rear suspension does not have enough travel to really maximize the dual rate coil. If you have this set up please feel free to enlighten me. Thanks for your help.
yea it will make your front end sit very low, look at the red and white one in the picture above you, it sits very low in the front
and the whole idea of duel rate spring is that it starts off with its softest spring rate and they get firmer as you go down, so even with dual rate, it would still be better than single rate of course, the beginning of the stroke would be soft for little bumps and rocks or whatever but then it gets stiffer the farther you cmpress it startss compressing the other springs, it really is nice to have more than a single rate spring
I dont think the dual rate setup would help for the rear shock it being so short. I think the rear progresive spring will work just fine given you have the rite spring rate setup.
I would just go with a +4 swingarm if you cant afford lonestar threre are some other way good ones out there without as big of a price tag as far as the rear shoch you can just leave the stock one on they can be calibrated to be as good as allot of the aftermarket shocks out there as far as the front ones i would go with elka shocks and a +2+1 a-arms from lonestar they look way good.
no offense, but dont listen to this guy.. +4 swingarm? why?? and why elka shocks and lonestar a arms.. because they look 'way" good? haha sorry that was funny though...elka must be puttin something in our water, cause everyone recemonds them, even without riding them or any other companies shocks
I was actually just thinking about why elkas are so much money. I have my truck sitting on king racing shocks (best shock in the desert-race proven) all the way around and the dam elkas cost more than my king coil overs? What the hell?
ALso does the banshee reaer shock have a rebound adjustor? I though the bottom of the shock had one but not sure.
