wacko2000 Posted October 7, 2007 Report Share Posted October 7, 2007 what do you guys use to measure the degrees? and where where can I get one?? Quote Link to comment Share on other sites More sharing options...
Banshee 79 Posted October 7, 2007 Report Share Posted October 7, 2007 what do you guys use to measure the degrees? and where where can I get one?? I sent you another PM, Here's a good guide to look thru when you start adjusting you front end http://www.lsracing.com/img/Guide_21.pdf Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted October 7, 2007 Report Share Posted October 7, 2007 I sent you another PM, Here's a good guide to look thru when you start adjusting you front end http://www.lsracing.com/img/Guide_21.pdf Okay thanks. Im going to print that.. Quote Link to comment Share on other sites More sharing options...
z28gabriel Posted October 7, 2007 Report Share Posted October 7, 2007 (edited) it looks like the upper arms are facing the wrong side Edited October 7, 2007 by z28gabriel Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted October 7, 2007 Report Share Posted October 7, 2007 it looks like the upper arms are facing the wrong side Is that in regards to my setup?? Quote Link to comment Share on other sites More sharing options...
Banshee 79 Posted October 7, 2007 Report Share Posted October 7, 2007 I E-Mailed ASR with pictures of how my top arms were put on and he said they were on the correct way. Take it for what it's worth! Quote Link to comment Share on other sites More sharing options...
z28gabriel Posted October 7, 2007 Report Share Posted October 7, 2007 Is that in regards to my setup?? no to Dgrey setup Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted October 7, 2007 Report Share Posted October 7, 2007 okay guys I sent ASR acouple pics of my setup to see what was going on and this is what they said From: AmStarRacingLLC@aol.com Add to Address Book Add Mobile Alert Date: Sat, 6 Oct 2007 20:43:37 EDT Subject: Re: (no subject) To: jojo0597@yahoo.com PS Make sure you set it up with 4 to 5 degrees of positive caster. This means the top arm trails behind the lower a-arm. When you look straight down at the Big Collar on the spindle side of the arm, you should see the entire top collar and the front 1/2 of the lower one when adjusted right. Any questions, just give us a call next week. The big swoop goes on the back just as you have it mounted. It is done that way for shock clearance. Quote Link to comment Share on other sites More sharing options...
fishwater Posted October 7, 2007 Report Share Posted October 7, 2007 I wonder if it is the difference between the old & the new arms? I am pretty sure I have the old arms, maybe they changed them? Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted October 7, 2007 Report Share Posted October 7, 2007 I was thinking the same thing..the ones that I have are new, They are the PSP, There could definately be a difference between new and old...I say what ever way you can get them to fit fuk it... Quote Link to comment Share on other sites More sharing options...
EastCoast Banshee Posted October 8, 2007 Report Share Posted October 8, 2007 Ok this should make it simple. Look at the threaded part of the a-arms where the ball joints thread in at. they should be slightly slanted towards the back of the quad if looking directly down on the installed a-arm. This goes for almost every a-arm iv seen for a banshee. Quote Link to comment Share on other sites More sharing options...
Hollister_Hitman Posted October 8, 2007 Report Share Posted October 8, 2007 (edited) Just confused now, which way did asr say was right? Edited October 8, 2007 by Hollister_Hitman Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted October 8, 2007 Report Share Posted October 8, 2007 Just confused now, which way did asr say was right? Hitman look at my pics.. ASR told me that I had it correct... From: AmStarRacingLLC@aol.com Add to Address Book Add Mobile Alert Date: Sat, 6 Oct 2007 20:37:58 EDT Subject: Re: (no subject) To: jojo0597@yahoo.com Hello! The big swoop goes on the back just as you have it mounted. It is done that way for shock clearance. Quote Link to comment Share on other sites More sharing options...
Hollister_Hitman Posted October 8, 2007 Report Share Posted October 8, 2007 ok yeah looks right becuase of the 1" forward do the shock mount should be 1" back and the upper need to clear the shock Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted October 8, 2007 Report Share Posted October 8, 2007 ok yeah looks right becuase of the 1" forward do the shock mount should be 1" back and the upper need to clear the shock this may be a stupid question but, how do you determine left to right? when you are on the bike or when you are standing infront of the shee looking at her? Only because in your pic the a-arms are labeled... im alittle confused. lol Quote Link to comment Share on other sites More sharing options...
