crazybanshee Posted December 24, 2007 Report Share Posted December 24, 2007 Thinking of trying the Skat-trak Edge instead of the sand skate 2. They look like a taller paddle. Thanks for all the info. Rippen we may have met at one time. I dune with alot of people from the Berthoud area. May have friends in common. Doug Quote Link to comment Share on other sites More sharing options...
theshee Posted December 24, 2007 Report Share Posted December 24, 2007 Thinking of trying the Skat-trak Edge instead of the sand skate 2. They look like a taller paddle. Thanks for all the info. Rippen we may have met at one time. I dune with alot of people from the Berthoud area. May have friends in common. Doug edges are very good v paddles. I use to run them on my raptor. I liked them better then sand stars. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted December 24, 2007 Report Share Posted December 24, 2007 I'm running this junk for hillshooting this year... 4mil gorr woods port in-frame shearers +2+1 arms w/ stock tires (my dune tires have too much offset and smash into trees) +4 swinger 35 pwk's on methanol (also have a set on gas) have a bunch of paddle and gearing options... 22" 10 paddle extremes 21" 9 paddle extremes 20" 10 paddle haulers I like the 20" 10 paddle haulers the most, but they dont give me the clearance I need for the hills rippen and theshee are talking about. I'd have a chain full of sand and some unhappy times... - Jared Quote Link to comment Share on other sites More sharing options...
kawiking Posted December 25, 2007 Author Report Share Posted December 25, 2007 i thought about that... theshee... why not a set of 22 ' instead of the 21's Quote Link to comment Share on other sites More sharing options...
theshee Posted December 25, 2007 Report Share Posted December 25, 2007 I dont really have a solid reason for the 21s. I just like how they work lol... I have 21-12-8 7 paddle superlites on my rap 700 and love them so I figured they would work well on the shee too. Quote Link to comment Share on other sites More sharing options...
kawiking Posted December 26, 2007 Author Report Share Posted December 26, 2007 do you try to run alot or mild compression ?? Quote Link to comment Share on other sites More sharing options...
theshee Posted December 26, 2007 Report Share Posted December 26, 2007 I run enough compression to go 50/50 race gas/ 91. 18cc domes. Quote Link to comment Share on other sites More sharing options...
kawiking Posted December 27, 2007 Author Report Share Posted December 27, 2007 what kind of race gas do you run ? i run vp c-12 .108 octane. what size cub piston u running ? i got some brand new stock 17 domes ill let you try out if u ever want to . Quote Link to comment Share on other sites More sharing options...
theshee Posted December 27, 2007 Report Share Posted December 27, 2007 what kind of race gas do you run ? i run vp c-12 .108 octane. what size cub piston u running ? i got some brand new stock 17 domes ill let you try out if u ever want to . not sure kind it is, but its 112 octane. Quote Link to comment Share on other sites More sharing options...
Hilarious Posted December 27, 2007 Report Share Posted December 27, 2007 Its a 4mil Fast duneport as Kiel mentioned.. So with that equals good torque from the 4mil as well as the porting... The porting on my bike is probably ported a tad more to the topend than a all out hill shooter may do but along with the 35mm Pwk's that plays a little into the duning/drag side. I also run the Vforce reeds which I belive helps with the quick low end throttle responce.. Also Iam running the Noss cool head.. Where we ride the compression is probably right around 158-160 psi range.. Good compression for the bottom but not so crazy it hurts some of the top(also I rather not run full race fuel-lol).. My pipes are CPI.. Again I was wanting something that comes on QUICK AND HARD.. But Cpi's also offer some top end so that goes back to the duning/drag side.. So with that setup this thing THROWS DOWN of the hills.. I wish we could go out and run the stuff that Sno does.. Being at sea level Be RIPPEN shit up-lol Iam not sure if thats what all your after man.. If there is anything I missed or a question you have feel free to ask!!! RIPPEN So, you're running 50/50 pump and race gas? I've got to check the compression in mine. I havent done that since I put my motor together. Your motor and mine are quite similar. Yours looks like it runs pretty damn good in the vids. :thumbsup: Quote Link to comment Share on other sites More sharing options...
kawiking Posted December 27, 2007 Author Report Share Posted December 27, 2007 im running 50/50 on my 140 lbs comp.. bike but im running a drag port and +5 timing.. great top end, not sure what domes im going to run... i want that top end and dont want to spend the crap out of my 9 paddle tripple buffs (i drag/play with it).. Quote Link to comment Share on other sites More sharing options...
RIPPEN Posted December 28, 2007 Report Share Posted December 28, 2007 So, you're running 50/50 pump and race gas?I've got to check the compression in mine. I havent done that since I put my motor together. Your motor and mine are quite similar. Yours looks like it runs pretty damn good in the vids. :thumbsup: Thanks The big difference obviously is going to be elevation.. Around here( around 5,000 ft) Iam about 165-170.. In Walden we are about 8,500 so it drops it down a bit more.. So yeah, it runs pretty damn good considering the elevation.. What elevation you at? RIPPEN Quote Link to comment Share on other sites More sharing options...
kawiking Posted December 28, 2007 Author Report Share Posted December 28, 2007 well .crap. i think we are 330 ft above sea level !!! Quote Link to comment Share on other sites More sharing options...
Hilarious Posted December 28, 2007 Report Share Posted December 28, 2007 Thanks The big difference obviously is going to be elevation.. Around here( around 5,000 ft) Iam about 165-170.. In Walden we are about 8,500 so it drops it down a bit more.. So yeah, it runs pretty damn good considering the elevation.. What elevation you at? RIPPEN I'm somewheres 100-200 ft above sea level. Yeah, there's the difference. lol It's a good climber. I'm even running damn near the same paddles as you. You say you've still got all stock suspension? I'm thinking seriously about tring out one of those rear marvin hillshooters with the coil over. :beer: Quote Link to comment Share on other sites More sharing options...
kawiking Posted December 29, 2007 Author Report Share Posted December 29, 2007 I'm somewheres 100-200 ft above sea level. Yeah, there's the difference. lol It's a good climber. I'm even running damn near the same paddles as you. You say you've still got all stock suspension? I'm thinking seriously about tring out one of those rear marvin hillshooters with the coil over. :beer: whay carbs do you have ?? Quote Link to comment Share on other sites More sharing options...
