2strokespirit Posted October 3, 2007 Report Share Posted October 3, 2007 Yes, any bike can be choke manually, does not matter if the choke works or not, by putting a towel over the intake instantly richen the mixture dramatic, like i said, i had the same problem, take off your carbs and swap the bowls so that the one with the fuel passage is on the carb with the chokelever, if u inspect the bowl you'll see they are differant. The last on who jetted the bike or cleaned the carbs must have put the wrong one on the wrong side. Now just go and do it. :-) Quote Link to comment Share on other sites More sharing options...
bigwake Posted October 3, 2007 Author Report Share Posted October 3, 2007 Yes, any bike can be choke manually, does not matter if the choke works or not, by putting a towel over the intake instantly richen the mixture dramatic, like i said, i had the same problem, take off your carbs and swap the bowls so that the one with the fuel passage is on the carb with the chokelever, if u inspect the bowl you'll see they are differant. The last on who jetted the bike or cleaned the carbs must have put the wrong one on the wrong side. Now just go and do it. :-) i'll check it out soon..and btw..do vf3's require a rejet? Quote Link to comment Share on other sites More sharing options...
