Way Better Than A Boost Bottle.
jayzx10r
I hate to be Heat Exchangers advocate but, it said your banshee would run 10 degrees cooler not give you 10 HP. If that did you give you 10HP though stacking heat exchangers would definately be the hot setup. They could probably even be modified to mount as an airbox lid then you would have COLD AIR INTAKE. Now we're talking. :yelrotflmao:
