BIGONTS Posted September 27, 2007 Report Share Posted September 27, 2007 I just cleaned the carbs and put new plugs in. The Right pipes aren't getting hot as fast, or as hot, as the left ones. The right plug is also kind of wet. After riding it around, they're about the same temp. The bike also doesn't got the kick down low put pulls really good up top. I checked the carbs and the slides are in sync, Choke tube in between the carbs. Any suggestions? Thanks Quote Link to comment Share on other sites More sharing options...
J-Madd Posted September 27, 2007 Report Share Posted September 27, 2007 Make sure the air screws are set the same on both carbs and also check the compression of both cylinders....go ahead and unplug the TORS and parking brake, too. Quote Link to comment Share on other sites More sharing options...
sredish Posted September 27, 2007 Report Share Posted September 27, 2007 crossover tube on the intakes? you might check compression on both cylinders as well to see if one's dropped some. Quote Link to comment Share on other sites More sharing options...
kawicat Posted September 30, 2007 Report Share Posted September 30, 2007 switch carbs and see if the heat problem also switches sides. If it does, check the float level, chokes, needle and tubes. Quote Link to comment Share on other sites More sharing options...
