dragbanshee Posted September 24, 2007 Report Share Posted September 24, 2007 (edited) no matter how i jet it or adjust it, my plugs seem to be wet so i thought i would try hotter plugs. seems to have helped keep plugs dry and runs alot better, just not sure if its safe to leave them in, since i run the bike wot full time, You know how it is! 280 mains, stock pilots,alba needles 4th notch rich, air screw 2 out ,pro reeds, k&n mod airbox lid, t5s plugs b7es. never done a compression check on it,and i do get a little bit of fuel out my silencers. but the bike runs really strong for stock. 1997 should i stick with standard b8es plugs? Edited September 24, 2007 by dragbanshee Quote Link to comment Share on other sites More sharing options...
sredish Posted September 24, 2007 Report Share Posted September 24, 2007 a plug with a hotter heat range, or colder heat range, just means it will transfer heat differently. the way you can tell if you need a different heat range is by reading the ground strap. there's a color change that occurs on there and it should occur in the middle of the bend. your plug being wet has nothing to do with the heat range. i suggest leaving the heat range alone. Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted September 24, 2007 Report Share Posted September 24, 2007 I use a different plug heat range when I'm jetting a bike and need to somewhat light off more unburned gas just like you did. If the bike likes those plugs and if the electrodes plating is not burned more than 1/2 the way down to the base of the plug then you are fine. I'd say your ignition/spark may be slightly off meaning it's not as hot as it once was. Check the plugs and you might get some new plug boots. Quote Link to comment Share on other sites More sharing options...
dragbanshee Posted September 25, 2007 Author Report Share Posted September 25, 2007 I use a different plug heat range when I'm jetting a bike and need to somewhat light off more unburned gas just like you did. If the bike likes those plugs and if the electrodes plating is not burned more than 1/2 the way down to the base of the plug then you are fine. I'd say your ignition/spark may be slightly off meaning it's not as hot as it once was. Check the plugs and you might get some new plug boots. thanks guys! i also was wondering would my bike be running as good as it is, reel good! if the rings were worn out? i wonder because of the eccess oil on plugs & a little out the silencers. Quote Link to comment Share on other sites More sharing options...
