Lethaface Posted September 24, 2007 Report Share Posted September 24, 2007 I just picked up a 1992 banshee on friday, And it seems to be having this problem. My dad pulled out the carbs and cleaned them, im thinking he put them back together wrong. Any help? Crossover tube in place?? The tube that connects the 2 carbs?? Also check the carbs and make sure they are sync'd.. Quote Link to comment Share on other sites More sharing options...
bigwake Posted September 26, 2007 Author Report Share Posted September 26, 2007 thanx everyone..i had a buddy come over and we checked the compression..checked out fine..120 each..we figured my choke is trash..idk why but it is..when it is on..the bike finally starts..i put the choke in and no difference in idle..so i need to find a new choke..thanx for all the help guys Quote Link to comment Share on other sites More sharing options...
sredish Posted September 26, 2007 Report Share Posted September 26, 2007 the choke can do it and the choke setup on the stock carbs is prone to problems.... glad you found it. Quote Link to comment Share on other sites More sharing options...
bigwake Posted September 26, 2007 Author Report Share Posted September 26, 2007 the choke can do it and the choke setup on the stock carbs is prone to problems.... glad you found it. got any pics of the choke..the way it should look? i want to see if i can still use my stuff..but maybe it needs a gasket or something?..it looks fine..but doesnt work Quote Link to comment Share on other sites More sharing options...
