CPI Pipes = Trimmed full Fenders ?
jbooker82
i use a jigsaw real slow. then when the trimming is done, use a propane or butane torch from the hardware store to smooth / finish the edges. if you just quickly graze the trimmed fender with the torch, go over it once, then go over it again, don't hold it in one place just back and forth until you see it start to get shiny. then let off. you'll end up with an edge that looks factory and is smooth and nice.
Sweet, that is the kind of tip I am looking for.
josh
do not hold the torch in one place for too long and work it slowly, you'll get the hang of it after you try it. but, if you hold it there too long, you'll obviously melt the stuff; the key is to heat to the point of almost melting and then letting it cool, it'll take to the original color and smooth out / gloss over.
You can also drill another hole in the fender to relocate the bracket about 1/2'' toward the bike, thus moving the fender outward. Worked for me.
I might try that too. Intead of drilling the hole I will just get a longer bolt for the fender bracket and put a 1/2 in spacer between the fender bracket and the frame. That shoudl do the same thing. :thumbsup:
