trinity head gasket?
nitroburner13
i recently bought an engine that had a trinity stage 4 head on it. when i took the head off there were no o rings on the domes but there are little metal rings on them and there are grooves machined in the top of the cylinders. i was told that i need a special copper head gasket for this head. is this true? i have always run pro design heads that were all o rings so i dont know about this. could anyone help me out? thanks
Yes, your Trinity head uses "fire rings" around the domes and require a dead soft copper gasket to seal against the cylinders. there are also o-rings to seal other areas of the head. Good news is they work better for big bore applications. You will more than likely have to call Trinity to get your parts. Probably 50 bucks just in seals. Those heads went over like a turd in a punch bowl because of their complexity. I am never excited to work with them.
Brandon
