oil mixture question
blakerman
Just get ya some Klotz and mix 4 ounces of oil to 1 gallon of gas. That's 32:1, I actually put a little more like 4.5 ounces to be on the safe side. Klotz is one of the best premixes out there so you can run less oil in your gas and still get good lubrication.
As was said, 32:1 or 40:1 is fine. Most decent oils will work in this range perfectly. I personally prefer 40:1 but nothing wrong with 32:1. 24:1 is too much, IMO.
Q: What type of two stroke oil should I use and what ratio?
A: Well that really depends on what kind of engine and fuel you are using. Generally the manufacturer
