Farmtruck Posted September 18, 2007 Report Share Posted September 18, 2007 I just bought a 02 shee it has T5 pipes, rejetted, K&N kit in stock air box no lid, boost tube and reed spacers I was told it has aftermarket reeds they do not say any on the side so I now their not VF3's so those are the mods it has stock motor. I am buying a noss head what cc domes will make good power with out hurting the stock motor, I don't mind running race gas I ride alot of trials and go to the dunes some too. Quote Link to comment Share on other sites More sharing options...
sredish Posted September 18, 2007 Report Share Posted September 18, 2007 whats the elevation where you ride. that'll make the most importance as to what cc domes to buy. if you talk to Dave about it when you purchase, he'll set you straight as well. Dave's a great guy and the Noss head is a great purchase. Click the link below and check out his little chart at the bottom that'll give you some compression ideas. Shoot for about 170 to 175 lbs. You don't want to get the compression up too much more than that as it'll do the nasty to your crank after a bit. If your sea level to 700 or 800 feet, 19s would work well, much over that, 18s would work good. Quote Link to comment Share on other sites More sharing options...
