1966nova Posted September 17, 2007 Report Share Posted September 17, 2007 i have a 80hp cub motor and noticed my tusk clutch slipping yesterday out riding so this morning i went to yamaha and bought R6 frictions and cleaned up my steels and reinstalled what a great diffrence very good any feedback out there????? on this r6 set up thanks greg Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted September 18, 2007 Report Share Posted September 18, 2007 the R6 setup is pretty much the same thing in the FZR1000... either way you shuld start looking into buying your self a lockup... that will be the last clutch you ever buy once you get it... Quote Link to comment Share on other sites More sharing options...
chevy7398 Posted September 18, 2007 Report Share Posted September 18, 2007 how much did it cost ya do do it??? Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted September 18, 2007 Report Share Posted September 18, 2007 you talking about the lockup or the R6 clutch? if your talking about the R6 all it is , is differant clutch fibers... they re about 9 bucks each... the lockup with a cover will run you like 375 Quote Link to comment Share on other sites More sharing options...
1966nova Posted September 18, 2007 Author Report Share Posted September 18, 2007 can you explain the lockup to me im very new to these bikes thanks is that where the clutch is not used in certain gears??? and will it make easier to hit gears because i miss a few alot when taking off like it goes to neutral... everyone told me its a banshee thing?? Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted September 18, 2007 Report Share Posted September 18, 2007 a lockup uses centrifugal force to open counter weights against the pressure plate cause it to "lock" the clutch allowing no slippage... It bolts up where your springs go on your pressure plate./ with this your shifting will be a little harder, that when alot of guy get override trannys. this allows you to change gears under full load without using your clutch.... Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted September 19, 2007 Report Share Posted September 19, 2007 Here is a pic of mine installed. Quote Link to comment Share on other sites More sharing options...
HardIzZlE Posted September 23, 2007 Report Share Posted September 23, 2007 Here is a pic of mine installed. soooooo shinyyyyyy :biggrin: Quote Link to comment Share on other sites More sharing options...
