banshee pissin me off
samc
banshee back firing and flooding out sounds like its running real rich, have to give it throttle for that beast to start
Let's start off with this.
Have you made any new changes that could have caused this?
Have you cleaned out your carbs?
Are the carbs synced?
What jets you running and at what elevation?
carbs been cleaned, im not sure on the elevation but i got 300 jets in there. i dont believe there synced, like it will back fire sometimes and i got it to rev up a couple times but that was when i was on the throttle hard kicking the shit out of it with the throttle wide open. i tried pop starting it down my road and it was like burp burp picked up and then just completly died. there fairly new plugs but i might of fouled them or something so imma try picking up some new ones.
sounds like a clogged pilot. take them apart and inspect the pilot jets and see if you find something.
i checked for spark and had barely no spark at all.
is that with new plugs or old plugs
if old get some new ones and try again
if new you got problems and it might be your coil (mine went out once and it did the same thing)
have funn
oh really? dang i hope thats not the problem.. i need to buy a flywheel puller. whats that little square kinda thing that has like 2 dots on it? i thought it was a ground and i zip tied to to the frame because i thought it might of popped off and couldnt think of any other way to get it on the frame but, i think it might be the throttle switch or a parking brake switch.
