4stroker Posted September 9, 2007 Report Share Posted September 9, 2007 hey guys i have a pro design intake with 33mm pwks on it at the moment and even with spacers on it the left carb hits on the clutch arm where it goes into the case and makes the clutch pull hard. i want to buy a new intake that i can use without spacers and clears the clutch arm with my keihins. does the boss racing intake do this? thanks, mark. Quote Link to comment Share on other sites More sharing options...
RZBansheeMan Posted September 9, 2007 Report Share Posted September 9, 2007 [topic= reed spacers, 3/4 inch ]Click here ![/topic] This should answer your ? Also did you ever put those massive ported RZ jugs on ? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted September 9, 2007 Report Share Posted September 9, 2007 You need a boss racing or white knucke intake. Here is a picture of my boss racing one. The carbs are moved back and up so they dont hit on the clutch arm. They also have a built in crossover tube so you dont have all that mess above your intakes. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted September 9, 2007 Report Share Posted September 9, 2007 Boss, Modquad, White Knuckle, and Majic Racing. all those are good intakes and will do what you need. plus they all have built in crossovers. Quote Link to comment Share on other sites More sharing options...
4stroker Posted September 10, 2007 Author Report Share Posted September 10, 2007 thanks guys looks like i will be ordering a boss intake! and yep i got those jugs on man it runs like a raped ape! currently having jetting issues with it (needs huge main jets) see jetting forum thanks, mark Quote Link to comment Share on other sites More sharing options...
