wheelieboy Posted September 8, 2007 Report Share Posted September 8, 2007 Ok I've got a ECATV built 610cc banshee motor. 16mm stroker crank, straight cut gears, lockup clutch and clutch cover mod. with CNC clear cover. This motor never seen the track. It has never made a pass. It was started warmed up idled down my drive way turned around and back. The case cover was broken when the kicker came out of the hole. Well its been heli arced. and doesn't leak. All my friends went to running bikes instead of quads. I'm ashamed but I'm joining the crowd. Heres what I have.. Full motor, straight cut gears, reeds, intake boots for 40mm carbs, Grand river Racing pipes each side out of frames. Dyna ignition WITH program software, and wiring harness. Help me out guys. This is all I have left, frame and everything has already been sold. I've got well over 7k in just the motor. I would like to have 4,500 out of all of it.. Plus shipping unless its local. I will email more pics. Thanks for reading. Chris. Quote Link to comment Share on other sites More sharing options...
wheelieboy Posted September 9, 2007 Author Report Share Posted September 9, 2007 Ok I've got a ECATV built 610cc banshee motor. 16mm stroker crank, straight cut gears, lockup clutch and clutch cover mod. with CNC clear cover. This motor never seen the track. It has never made a pass. It was started warmed up idled down my drive way turned around and back. The case cover was broken when the kicker came out of the hole. Well its been heli arced. and doesn't leak. All my friends went to running bikes instead of quads. I'm ashamed but I'm joining the crowd. Heres what I have.. Full motor, straight cut gears, reeds, intake boots for 40mm carbs, Grand river Racing pipes same side out of frames. Dyna ignition WITH program software, and wiring harness. Help me out guys. This is all I have left, frame and everything has already been sold. I've got well over 7k in just the motor. I would like to have 4,500 out of all of it.. Plus shipping unless its local. I will email more pics. Thanks for reading. Chris. Quote Link to comment Share on other sites More sharing options...
madracing Posted September 9, 2007 Report Share Posted September 9, 2007 pics to mdoty@bak.rr.com also your location Quote Link to comment Share on other sites More sharing options...
wheelieboy Posted September 12, 2007 Author Report Share Posted September 12, 2007 pics to mdoty@bak.rr.com also your location I'll get them to you asap. I just got in from military duty. Thanks for your patients. Quote Link to comment Share on other sites More sharing options...
banshee332 Posted September 12, 2007 Report Share Posted September 12, 2007 I'll get them to you asap. I just got in from military duty. Thanks for your patients. price on strigt cuts and 16mill crank if you split up motor. Quote Link to comment Share on other sites More sharing options...
wheelieboy Posted September 13, 2007 Author Report Share Posted September 13, 2007 price on strigt cuts and 16mill crank if you split up motor. Sorry really don't want to split it. I would probable end up with parts I couldnt' sell. sorry.. Quote Link to comment Share on other sites More sharing options...
wheelieboy Posted September 13, 2007 Author Report Share Posted September 13, 2007 (edited) I have the work up sheet from East Coast where Dave G. built this motor. I have over 4k in performance motor parts alone. Then theres the Drag port work triple exhaust port intake port work. I don't think I'm asking to much for all this. You won't find all this any better.. Thanks going to Iraq again soon. Need to move. I'm losing well more than I'm getting.. but I've excpeted that.. (OFFERS CONSIDERED) Edited September 13, 2007 by wheelieboy Quote Link to comment Share on other sites More sharing options...
wheelieboy Posted September 19, 2007 Author Report Share Posted September 19, 2007 I have the work up sheet from East Coast where Dave G. built this motor. I have over 4k in performance motor parts alone. Then theres the Drag port work triple exhaust port intake port work. I don't think I'm asking to much for all this. You won't find all this any better.. Thanks going to Iraq again soon. Need to move. I'm losing well more than I'm getting.. but I've excpeted that.. (OFFERS CONSIDERED) OK well I'm dropping it to 3500.00 Any takers? +shipping. Quote Link to comment Share on other sites More sharing options...
Whitey Posted September 20, 2007 Report Share Posted September 20, 2007 OK well I'm dropping it to 3500.00 Any takers? +shipping. Where are you located? I'm about a half hour from ECATV so if your stuff is still there or you live around there than we can avoid shipping. My buddy has a 421 PV Cheetah that we're about to pull out and have drag ported and the powervalves removed, it might be cheaper just to buy your setup and sell the 420. Let me know if you still have everything and maybe we can work something out. Also what reeds are in it? Quote Link to comment Share on other sites More sharing options...
wheelieboy Posted September 21, 2007 Author Report Share Posted September 21, 2007 (edited) Where are you located? I'm about a half hour from ECATV so if your stuff is still there or you live around there than we can avoid shipping. My buddy has a 421 PV Cheetah that we're about to pull out and have drag ported and the powervalves removed, it might be cheaper just to buy your setup and sell the 420. Let me know if you still have everything and maybe we can work something out.Also what reeds are in it? It has 250r reeds in it. I think thats what Dave put in it. If you know Dave and want to ask him about it. Tell him Chris in North Carolina. 28645. I still have it all complete motor lock up clutch. dyna fx and software, coil clutch lever, GRR pipes. and wireing harness. Edited September 21, 2007 by wheelieboy Quote Link to comment Share on other sites More sharing options...
Whitey Posted September 21, 2007 Report Share Posted September 21, 2007 It has 250r reeds in it. I think thats what Dave put in it. If you know Dave and want to ask him about it. Tell him Chris in North Carolina. 28645. I still have it all complete motor lock up clutch. dyna fx and software, coil clutch lever, GRR pipes. and wireing harness. I'm definitely interested. Give me your phone number and I'll give you a call this weekend so we can work out the details. Quote Link to comment Share on other sites More sharing options...
wheelieboy Posted September 22, 2007 Author Report Share Posted September 22, 2007 I'm definitely interested. Give me your phone number and I'll give you a call this weekend so we can work out the details. PM Sent. Thanks Chris Quote Link to comment Share on other sites More sharing options...
