seabass Posted September 8, 2007 Report Share Posted September 8, 2007 I can pick one up for under $100. Are they any good? Do you need to change the bolts or can you use the stock ones? Any feedback is appreciated. Quote Link to comment Share on other sites More sharing options...
XxMeltIcexX Posted September 8, 2007 Report Share Posted September 8, 2007 I can pick one up for under $100. Are they any good? Do you need to change the bolts or can you use the stock ones? Any feedback is appreciated. Friends got one and he likes it, id pick it up for less than 100 bucks for sure, alot better than stock. Im pretty sure its the same as a pro design but im not positive. You do have to use extended studs. Eric Quote Link to comment Share on other sites More sharing options...
shanYE west Posted September 8, 2007 Report Share Posted September 8, 2007 Its pretty much the same thing as a Pro-Design Cool head. The only difference is the top shell looks different. They still use the same domes and uses the longer studs. I actually prefer the Power head over a cool head because its alot easier to polish the top shell. Quote Link to comment Share on other sites More sharing options...
odaen Posted September 9, 2007 Report Share Posted September 9, 2007 Its pretty much the same thing as a Pro-Design Cool head. The only difference is the top shell looks different. They still use the same domes and uses the longer studs. I actually prefer the Power head over a cool head because its alot easier to polish the top shell. Yeah, I had one on my old 4mm, and it was super easy to polish too, like fouledout said. Never had a problem with it.... Quote Link to comment Share on other sites More sharing options...
