PowerBand Delay
kskjofire
I got the airbox w/t6 air filter and like 8 or 10 holes, no snorkel. What do you think?
So, basically you have the whole Toomey TR6 modified airbox pipe kit.
I am not a jetting genius, but it sounds to me like the needle needs adjustment. Adjusting the needle has also been mentioned by others, and it is easy to do. I would try that at least.
I took the time to do a plug chop, and my banshee runs strong and is quite fast for what it is...
  • Replies 38
  • Created
  • Last Reply
Top Posters In This Topic
I go it in the 4clip. shouldI moved to the 3rd clip?
well move it and see if it makes a difference.
Yep Move / Change the needle. Sometimes it is good to go with a longer needle with less taper.
If you really don't think it is a jetting issue, then check your reeds (this will require some new gaskets to pull them and inspect them).
Better reeds = better throttle response.
When you ride the Banshee, look for a throttle position right before the Power Band, this way when your curizing on a hill you have instant access to the power. You don't lug it then gun it like you can with a 4-stroke. it really does sound like a jetting issue to me though, definately with the needle or maybe even the main jet! (transition between needle and fully open is the problem)
I ran 320's mains with FMF Fattys No lid on airbox, and K&N @ sea level in glamis moved the stock needle clip down 1 position (Raised the needle). I was typicaly slightly rich but never foweled a plug!
Edited by Justintoxicated
HEY Justin were do you recoment me go w/ the needle, I am going to ride tomorro. My needle has 6 grooves
