Snopczynski Posted September 8, 2007 Report Share Posted September 8, 2007 (edited) Jetting can severly augment the way power delivery feels. It may be alot different if your jetting and needle position still needs to be adjusted. What was this bike like before you put these parts on? What pipes, etc......? Edited September 8, 2007 by Snopczynski Quote Link to comment Share on other sites More sharing options...
hyperlite33 Posted September 8, 2007 Report Share Posted September 8, 2007 I don't know if your interested, but I have a set of FMF Gnarley pipes that "get into the pipe" pretty quick that I will be selling. :biggrin: They are considered a low to mid range pipe. Might help in off the line racing!! Quote Link to comment Share on other sites More sharing options...
kskjofire Posted September 9, 2007 Author Report Share Posted September 9, 2007 Jetting can severly augment the way power delivery feels. It may be alot different if your jetting and needle position still needs to be adjusted. What was this bike like before you put these parts on? What pipes, etc......? Maybe a need to adjust my needle and jets, igot my needle in the 4 clip i am going to the 3rd and see. Quote Link to comment Share on other sites More sharing options...
kskjofire Posted September 9, 2007 Author Report Share Posted September 9, 2007 Its not what you guys think(the driver). I think something is wrong before the POWER BAND. GOT dirt bikes dont feel like that. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted September 9, 2007 Report Share Posted September 9, 2007 always set main first, then needle, then pilot and air screw. Quote Link to comment Share on other sites More sharing options...
kskjofire Posted September 9, 2007 Author Report Share Posted September 9, 2007 always set main first, then needle, then pilot and air screw. i got 280main, needle 4 clip and stock pilot. What do you recomend me? sea level Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted September 9, 2007 Report Share Posted September 9, 2007 Run it wide open and check the plug color. Quote Link to comment Share on other sites More sharing options...
kskjofire Posted September 9, 2007 Author Report Share Posted September 9, 2007 Thats my next step. But my problem is i dont have the space around my house to hit all the gears. Quote Link to comment Share on other sites More sharing options...
shee rips Posted September 9, 2007 Report Share Posted September 9, 2007 Its not what you guys think(the driver). I think something is wrong before the POWER BAND. GOT dirt bikes dont feel like that. i had a yz 125 and it was a bit of an adjustment goin to the banshee because even the 125 hit a little sooner, but not nearly as hard as the banshee did with just pipes. if you are used to a 250 2 stroke dirtbike then the banshee will definitly feel sluggish off the bottom. this is not to say that you dont have a possible jetting issue. what is your compression? Quote Link to comment Share on other sites More sharing options...
sredish Posted September 9, 2007 Report Share Posted September 9, 2007 If it's coming on while your hitting the throttle, try raising the needle 1 clip or even 2, you can always put it back. Pay close attention tot he throttle position, if its fine until you hit WOT, then it's more likely to be the main and you'll want to switch that. The needles are easy to play with so just try that real quick and see if it helps. Quote Link to comment Share on other sites More sharing options...
BSHEE400 Posted September 9, 2007 Report Share Posted September 9, 2007 i found the best mod to eliminate this delay was to "GO BIGGER" try boring the cylinders and adding 2.5mm oversize pistons. it brings it to about 402cc makes a massive difference from the bottom to the top, it laughs at 4bangers. or you could be more aggressive with the clutch to pick up the revs and "RING ITS NECK" but hey what do i know i'm only a rookie here at HQ Quote Link to comment Share on other sites More sharing options...
Coupelx Posted September 9, 2007 Report Share Posted September 9, 2007 i found the best mod to eliminate this delay was to "GO BIGGER" try boring the cylinders and adding 2.5mm oversize pistons. it brings it to about 402cc makes a massive difference from the bottom to the top, it laughs at 4bangers. or you could be more aggressive with the clutch to pick up the revs and "RING ITS NECK" but hey what do i know i'm only a rookie here at HQ i use the rev and dump to keep the rpms up too. My clutch hates me :happy: Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted September 9, 2007 Report Share Posted September 9, 2007 (edited) i found the best mod to eliminate this delay was to "GO BIGGER" try boring the cylinders and adding 2.5mm oversize pistons. it brings it to about 402cc makes a massive difference from the bottom to the top, it laughs at 4bangers. or you could be more aggressive with the clutch to pick up the revs and "RING ITS NECK" but hey what do i know i'm only a rookie here at HQ so your saying take a fresh cylinder and bore it out to the max of .100 over to get gains to beat a 4 stroke? if so your a god damn fool. thats the worst advice iv heard in a long time! there is plenty of other thing you can do to that motor without killing the life of it to get a bigger piston in there. edit: oh and that makes it a 382 not a 402 Edited September 9, 2007 by Bansh-eman Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted September 10, 2007 Report Share Posted September 10, 2007 Ok guys My Banshee has like 1 or 2 seconds DELAY to hit the power band. This is my first Shee. Is this normal? O and is happening in 1st and 2 gear. I got 06shee, T6's, VF3, T jet kit, 280 main, clip in the 4 grove, +4 plate, stock carb and 1 1/2 aircrew. THANK GUYS FOR ALL THE HELP. IF I RACE W/my friend that delay is killing me. You did not mention anything about what type of air filter you are running. Does that mean you have the airbox, stock filter, and snorkel installed? With performance exhaust systems, that engine needs to breath! If your intake is completely stock, you may be rich on the main and the needle. Clean your carbs real good, check the float level, and then check your jetting with a good old fashioned plug chop. It will tell you everything you need to know. As mentioned above, start with the mains, then needle, then airscrew and pilot. Once the jetting is right, it is much easier to further investigate problems the correct jetting did not solve. How Carburetors Work What Is Jetting Troubleshooting Your Jetting Issues Plug Chop No boring necessary for this problem..... Quote Link to comment Share on other sites More sharing options...
kskjofire Posted September 10, 2007 Author Report Share Posted September 10, 2007 You did not mention anything about what type of air filter you are running. Does that mean you have the airbox, stock filter, and snorkel installed? With performance exhaust systems, that engine needs to breath! If your intake is completely stock, you may be rich on the main and the needle. Clean your carbs real good, check the float level, and then check your jetting with a good old fashioned plug chop. It will tell you everything you need to know. As mentioned above, start with the mains, then needle, then airscrew and pilot. Once the jetting is right, it is much easier to further investigate problems the correct jetting did not solve. How Carburetors Work What Is Jetting Troubleshooting Your Jetting Issues Plug Chop No boring necessary for this problem..... I got the airbox w/t6 air filter and like 8 or 10 holes, no snorkel. What do you think? Quote Link to comment Share on other sites More sharing options...
