Bansh-eman Posted August 30, 2007 Report Share Posted August 30, 2007 i know its not right spot, but this will get everyones attention. if you could do these two problems and explain how you did it. 1/6 x 36 - 7 -------------- 4 + 1/5 x 25 that would read out (1 over 6 x 36 - 7) Over ( 4 + 1 over 5 x 25) jus casue i cant make it look exactly the same on the forums the second would be -5^2 - 10 x (-5) + 5 ----------------------- -5^2 + 2 x (-5) - 1 -5^2 means negitive 5 squared the ^ denotes exponant. Quote Link to comment Share on other sites More sharing options...
SoCalinIt Posted August 30, 2007 Report Share Posted August 30, 2007 Is the first answer -0.988 and I think the second one is... 105 Right??? Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted August 30, 2007 Author Report Share Posted August 30, 2007 Is the first answer -0.988 and I think the second one is... 105 Right??? not according to the options... i should have said that Evaluate the expression of 1/6 x 36 - 7 -------------- 4 + 1/5 x 25 and Evaluate the expression for the given value of the variable. -5^2 - 10 x (-5) + 5 ----------------------- -5^2 + 2 x (-5) - 1 the possible anwers are 13/9 , 1, -1/9, 1/9 and the second possibles are 40/7, 5, -10/7, -40/7 Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted August 30, 2007 Author Report Share Posted August 30, 2007 (edited) ok so 1/6 x 36 - 7 -------------- 4 + 1/5 x 25 was -1/9 now i got to figure out the other edit: i think the second is 40/7.... anyone else get the same or anything differant? Edited August 30, 2007 by Bansh-eman Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted August 30, 2007 Author Report Share Posted August 30, 2007 those where correct that i posted... but i guess i need to look over a few other thing casue i got some of what i thought where ez ones wrong Quote Link to comment Share on other sites More sharing options...
SoCalinIt Posted August 30, 2007 Report Share Posted August 30, 2007 Yeah.... I have no idea. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted August 30, 2007 Author Report Share Posted August 30, 2007 Yeah.... I have no idea. lol thats how i felt. and this is the very beginning of the math. its going to get alot harder and i havent been in highschool for a little bit of time now Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted August 30, 2007 Report Share Posted August 30, 2007 not according to the options...i should have said that Evaluate the expression of 1/6 x 36 - 7 -------------- 4 + 1/5 x 25 and Evaluate the expression for the given value of the variable. -5^2 - 10 x (-5) + 5 ----------------------- -5^2 + 2 x (-5) - 1 the possible anwers are 13/9 , 1, -1/9, 1/9 and the second possibles are 40/7, 5, -10/7, -40/7 The key here is order of operations: () first, then X and /, then + and - . And also remember (a/B)/(c/d) is equivalent to (a/B) x (d/c). Looks like you might have those down. :thumbsup: Quote Link to comment Share on other sites More sharing options...
bonbon Posted August 30, 2007 Report Share Posted August 30, 2007 (edited) i know its not right spot, but this will get everyones attention. if you could do these two problems and explain how you did it. 1/6 x 36 - 7 -------------- 4 + 1/5 x 25 that would read out (1 over 6 x 36 - 7) Over ( 4 + 1 over 5 x 25) jus casue i cant make it look exactly the same on the forums the second would be -5^2 - 10 x (-5) + 5 ----------------------- -5^2 + 2 x (-5) - 1 -5^2 means negitive 5 squared the ^ denotes exponant. First one is -1/9 Top: 1/6x36=6 minus 7 = -1 Bottom: 1/5x25=5 plus 4 = 9 so, -1/9 Second one is 40/7 Top: -5 squared is 25 minus (-50) = 75 +5 =80 (the two negatives mean you add the 25 and 50, -(-50) is same as +50) Bottom: -5 squared is 25 plus (-10) = 15 -1 =14 (adding the negative 10 is same as subtraction) Now you have 80/14, when simplified as far as it can go you get 40/7 (just divide by 2) Hope that made some sense EDIT: I just read the rest of the other posts and saw you figured it out. :thumbsup: It actually took me a second, I haven't done math in a while and the last was all calc so I forget how to do fractions and the order of operations lol. Edited August 30, 2007 by bonbon Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted August 30, 2007 Author Report Share Posted August 30, 2007 yea i havent done any math in almost 7 years, given this is only highschool lvl mah its hard to remeber all the equations and shit from 7 years ago.... Quote Link to comment Share on other sites More sharing options...
SoCalinIt Posted August 30, 2007 Report Share Posted August 30, 2007 Yeah... I'm lost man! I have not done math in years... My wife is really good at that sh!t, but she is a teacher. Quote Link to comment Share on other sites More sharing options...
FireHead Posted September 1, 2007 Report Share Posted September 1, 2007 First one is -1/9Top: 1/6x36=6 minus 7 = -1 Bottom: 1/5x25=5 plus 4 = 9 so, -1/9 Second one is 40/7 Top: -5 squared is 25 minus (-50) = 75 +5 =80 (the two negatives mean you add the 25 and 50, -(-50) is same as +50) Bottom: -5 squared is 25 plus (-10) = 15 -1 =14 (adding the negative 10 is same as subtraction) Now you have 80/14, when simplified as far as it can go you get 40/7 (just divide by 2) Hope that made some sense EDIT: I just read the rest of the other posts and saw you figured it out. :thumbsup: It actually took me a second, I haven't done math in a while and the last was all calc so I forget how to do fractions and the order of operations lol. U R Edumicated. :biggrin: Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted September 4, 2007 Author Report Share Posted September 4, 2007 i thought this shit hard figureing out after getting started... little did i know we have to do fuking statistics! that shits just retarded! they really figured out a way to make an average person feel fuking stupid thats for sure! Quote Link to comment Share on other sites More sharing options...
FireHead Posted September 4, 2007 Report Share Posted September 4, 2007 i thought this shit hard figureing out after getting started... little did i know we have to do fuking statistics! that shits just retarded! they really figured out a way to make an average person feel fuking stupid thats for sure! Statistics are actually kind of fun, or atleast I think so. It's Statics that is the real bitch. Between Statics and multi-diff. calculus I am pretty sure I killed more brain cells than I did retain information to fill them. :geek: Quote Link to comment Share on other sites More sharing options...
dajogejr Posted September 4, 2007 Report Share Posted September 4, 2007 Seriously...my brain hurts. Quote Link to comment Share on other sites More sharing options...
