banshee assault Posted August 30, 2007 Report Share Posted August 30, 2007 Does anyone know where to find just the rubber boots on the stock A-arms? (The rubber boot that goes over the ball joint.) I can't locate a part # for just the rubber boots. I contacted my local dealer and they said I have to buy the entire A-Arms to get the boots! :: Also, what is the best way to seperate the A-Arm from the spindle? I am trying to restore my banshee and these are the only pieces I have left to disassemble. sorry for the noob q's. Thanks Quote Link to comment Share on other sites More sharing options...
letsgetthisdone Posted August 30, 2007 Report Share Posted August 30, 2007 you use a balljoint fork to get the a-arms off of the spindles... and your dealer isn't lieing to you. i just looked at a parts list breakdown on a dealer website, it shows pix of the assemblies and all of the parts are numberedand what not, the boots come with the a-arms. if the boots are messed up are the joints are worn out you can put get aftermarket +2+1 arms and some shocks to go with them for under $1,000. and it'll ride a lot better than stock.. Quote Link to comment Share on other sites More sharing options...
okbeast Posted August 30, 2007 Report Share Posted August 30, 2007 I've got some extra boots on some arms that are bent, pm me if you want 'em, not sure how many are good though, let me know how many you need. Quote Link to comment Share on other sites More sharing options...
banshee assault Posted August 30, 2007 Author Report Share Posted August 30, 2007 letsgetthisdone where can I find the shocks and arms for under 1G? Would they be new? Thanks for looking Quote Link to comment Share on other sites More sharing options...
nunyabinness Posted August 30, 2007 Report Share Posted August 30, 2007 you can get just the rubber boots. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...653378&rd=1 as for getting the spindles off of the a-arms (without damaging anything) take the brakes apart so that you have a bare spindle. then take the castle nuts off of the ball joints. then take a hammer (don't use a rubber mallet it won't work) and hit the spindle right next to the ball-joint you are trying to remove. a few good whacks and the ball-joint will just pop right out. Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted August 30, 2007 Report Share Posted August 30, 2007 you can get just the rubber boots. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...653378&rd=1 as for getting the spindles off of the a-arms (without damaging anything) take the brakes apart so that you have a bare spindle. then take the castle nuts off of the ball joints. then take a hammer (don't use a rubber mallet it won't work) and hit the spindle right next to the ball-joint you are trying to remove. a few good whacks and the ball-joint will just pop right out. I "made" a real nice ball joint separator for the banshee spindles that was easy out of some older parts I had laying around. I used a "drag" style lug nut, open all the way through, and a fine thread (just what the lug nut happened to be) 1/2" bolt. Essentially, you take one castle nut off and thread the bolt and lug nut apart until it provides pretty good pressure, then with one, two at most usually, medium hits with a ball peen hammer it will pop right loose. Plus, you'll never damage a boot this way. As far as balljoint separators or pickleforks or whatever, I have a whole mess of them, but have yet to find one that will work, so not sure about that. Quote Link to comment Share on other sites More sharing options...
banshee assault Posted August 31, 2007 Author Report Share Posted August 31, 2007 OK thanks guys, will try this and let you know. Quote Link to comment Share on other sites More sharing options...
