peterlocal22 Posted August 29, 2007 Report Share Posted August 29, 2007 want to buy some ice from rockey mountain but trying to figure out how many 64 oz containers i need? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted August 29, 2007 Report Share Posted August 29, 2007 1. My banshee take 1 64oz bottle and that is with my prodesing radiator. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted August 29, 2007 Report Share Posted August 29, 2007 dude go to walmart and u can get the regular stuff for under $10. works great. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted August 29, 2007 Report Share Posted August 29, 2007 dude go to walmart and u can get the regular stuff for under $10. works great. by regular stuff i hope you are not talking about anti freeze? Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted August 29, 2007 Report Share Posted August 29, 2007 (edited) yup. works great for me. You can even buy it already mixed 50/50. now i guess there's some negative things about using it...... Edited August 29, 2007 by RagunCajun Quote Link to comment Share on other sites More sharing options...
SoCalinIt Posted August 29, 2007 Report Share Posted August 29, 2007 I use the Engine Ice in all my bikes... Works good IMO. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted August 31, 2007 Report Share Posted August 31, 2007 yup. works great for me. You can even buy it already mixed 50/50. now i guess there's some negative things about using it...... anti freeze is just that. its made to keep your fuild from freezing in low temps. but it does not add any extra cooling. engine ice and water wetter add more cooling proctecti0on over just running distilled water, they also have a lubricant in them that keeps your seals from drying out. Quote Link to comment Share on other sites More sharing options...
wesw Posted August 31, 2007 Report Share Posted August 31, 2007 anti freeze is just that. its made to keep your fuild from freezing in low temps. but it does not add any extra cooling. anti freeze/coolant sure seems to work very well in my truck and semi. really think my semi needs plenty of cooling being its 95 degs out and pulling in the hills. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted August 31, 2007 Report Share Posted August 31, 2007 I've never had a problem with 50/50 mix over heating in the dunes. Since I've never had a problem with overheating.. I dont think I would spend the 20.00 for ice.. The only reason I use Ice is for cosmetic apperance. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted August 31, 2007 Report Share Posted August 31, 2007 If engine ice wasnt so expensive, then i would use it. However, i will keep using 50/50. It's cheap. Engine ice is like other things for our bikes, marked up in price just because they can. I also buy type f tranny fluid too. I try to cut cost every way i can. I have some engine ice left so i will probably use it in my shee once i get the problems out of it fixed. I hate tearing it down over and over again and losing expensive engine ice. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted August 31, 2007 Report Share Posted August 31, 2007 (edited) If engine ice wasnt so expensive, then i would use it. However, i will keep using 50/50. It's cheap. Engine ice is like other things for our bikes, marked up in price just because they can. I also buy type f tranny fluid too. I try to cut cost every way i can. I have some engine ice left so i will probably use it in my shee once i get the problems out of it fixed. I hate tearing it down over and over again and losing expensive engine ice. I change mine every year sometimes 2 or more times. It's expensive but it works and it's a good product and non toxic. And since I always spill coolant, I like the fact it is not toxic. Looks like blue coolaid! You could also try Pentosin coolant, it is also blue and cheaper. Has super anti corrosion in that stuff likely much better than engine ice. Edited August 31, 2007 by Justintoxicated Quote Link to comment Share on other sites More sharing options...
peterlocal22 Posted September 1, 2007 Author Report Share Posted September 1, 2007 now should i mix water w the ice or just pour it in w no mixing? Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted September 1, 2007 Report Share Posted September 1, 2007 Engine ice is ready to use. DO NOT mix with water. Says that on the container:) Quote Link to comment Share on other sites More sharing options...
FireHead Posted September 1, 2007 Report Share Posted September 1, 2007 yup. works great for me. You can even buy it already mixed 50/50. now i guess there's some negative things about using it...... There isn't anything really negative about using it, you just do not get the surfactant qualities that you would with Engine Ice or Water Whetter (not an antifreeze). :geek: Quote Link to comment Share on other sites More sharing options...
