loose seat fix.....
JET 99
here are some pics of the fix....
1/8 in drill bit
1/4 in drill bit
single flute chamfer tool
1/4 20 nuts(4),1/4 in fender washer(2),1/4 in flat&lock washers(2ea),1/4 20 thread rubber stopper...
the (4) 1/4 20 nuts takes a wrench on top and a deepwell socket on bottom
used as jam nut.. dont over tighten rubber plug use jam nuts to hold in place :biggrin:
hope you guys approve!!!!!!!!!!!!
Look at where those rubber stopers rest against the seat. I bet your missing the two front rubber bushings. There sould be rubber stopers in the seat where those 2 rubber stoppers hit.
Most of the time the front ones are missing. They are just made of rubber. UPP Racing makes a set of replacement ones that are made out of Poly. Two short ones in the front two tall ones in the rear.
Here is the right fix.
UPP Racing Seat Nubbins LINK
i have about $00.00 in this mod. i work in a machine shop (the stuff was laying around).....all it took was my time. the rears were on there.. so i saved $22.00 to put in the gas tank... it didnt hurt a thing and the plugs line right up with the hole were your nubbins go :biggrin: :biggrin: :biggrin: sorry if you think its redneckish!!!!!!!!!!!!!!!!!
why do that, i love replacing mine every time i go out :banghead: :shoothead: :banghead:
so do you approve or think i f---ed it up..
it works for me they were not on there when i bought the shee.
i thought i had read in here a couple years ago that they magically can disappear while riding????
so why piss money away ... the stopper was only a couple bucks in the MSCINDUSTRIALSUPPLY catalog.. so i would be out 6 bucks if i bought the stuff...
:huh::huh::huh:
Everyone has their own ways of doing things, me personally - i wouldnt have done it cause my Powdercoat, and cause i dont like more weak spots on my frame, (a banshee frame is already weak) not like thats a crucial weak spot... Ive never lost my seat bumpers, and mines a 96.
Eric
:huh::huh::huh:
looks ok to me.
they do magically disappear... after loosing two i checked often, only found one once in by the clutch arm.
I approve, I always loose them no matter how hard I tryi to keep em secure.
I dig this mod & understand about making the frame weak but I think Shee can handle it.
Good job & props on the mod !
i figured if (2) 1/4 in holes are the weak link in my frame i probably shouldnt go as fast as i do on it...... :woot: :woot: :woot:
Gorilla Glue that shit in place...or some kind of glue anyways :P I lost mine too but they are cheap to replace. I added some rubber padding to the top of the rear plastics (Where the wear marks on them are) as well to eliminate all side to side play. And all banshees I have ever sceen have side to side play in the seat to some extent.
Your mod is fine though.
