gforce axle install any tips?
sd1
Its pretty straight forward.
You want to loosen the locknuts on the stock axle before you do anything else.
There are many ways to do this. Sometimes it will be a painful task. Lol
Once you have that did, remove tires & hubs.
Remove the locknuts. Loosen chain and remove sproket hub, it should slide off.
Pull axle out through right side of carrier. Slide brake disc hub off axle.
Install is reverse.
I would recommend cleaning out your carrier before you install the new axle. And
install new bearings and seals while you have it apart.
Pack it with grease and dont forget to re-install the spacer
between the bearings.
Once you are back up and running, periodically check the new locknut and tighten
as necessary.
:beer:
This is all you need & you're good! I had to use a big wrench with pipe over it to get the first stock locknut off, second one wasn't budging so I attacked with the grinder. I didn't use loctite either. The G Force uses a posi locknut. No prob's here.
  • 2 months later...
I like the black on your sprocket hub man, is the brake hub the same ?
What did you use ...im going to paint my hubs black this winter so i was just wondering how much preping did it take to look that good.
