are raptor shocks the same size as banshees?
sd1
im looking into getting some shocks for my quad saw that the elka recreational shocks are only dual rate springs and not triple....was wondering why ... I called elka and even they really didnt know lol.....and i see raptor elkas are triple rate in the recreational style......i will be going with +2 aarms also......alba has a decent kit......any advice on this would be great thx...i do mostly desert style riding...non sand dunes just open desert......in the non resevoir style are the works G series shocks better?......also when i called alba and asked them about weight vavling they said all we need to do is put a heavier spring on the shock and the valving stays neutral...are the full of it?
ive got a nice set of 5 month old TCS remote rezzie dual rates zero preload with compression and ride height adjustment.....
they might have 15 hrs on em....im selling because im goin to a drag dike.
ill make you a smokin deal....pm me for more info
Dan
  • 2 weeks later...
hmm ok....I will be running +2 arms tho will that help?
It depends on the mounting tabs if you can run the shocks Do you have long travel or stock lenght shock a-arms. There is a difference. You can install the YFZ shocks on OEM banshee a-arms if you have the shock a bit. I have some aftermarket a-arms where the mounting bracket has some extra height to it which allows the sock to clear.
Raptor eyes [shock mounts] are very slim like stock Banshee shocks, YFZ's are bulky which is the reason for modifying onto the Banshee. Raptor shocks are longer & think it's a bad idea putting expensive shocks that are too long onto the Banshee stock arms. I'd see Dan first for that TCS setup he has before anything :thumbsup:
