DSSA Posted August 6, 2007 Report Share Posted August 6, 2007 Ok guys, heres the scoop on what I found........ You may or may not belive me but for $4 its worth your effort. We found a new spark plug that advances the timing 2 degrees, We first tested it on snowmobiles and made 3 horsepower on the dyno over BR9 ES's with an 800cc snowmobile motor. They are made by Champion and they are called RN57YC . Just recently I put them in the banshee and noticed that it does help with throttle response which means that they do make power. Just a heads up. Also if you decide to try them they would be at an auto parts store and I have found them as cheap as $1.87 a piece. :yelrotflmao: Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 6, 2007 Report Share Posted August 6, 2007 So far, I've learned that:1. Champion plugs can give you a 2 degree ignition advance...I call it detonation or pre-ignition because the "lug" < :thumbsup: extends farther into the combustion chamber than needed. You get more "advance" the hotter the plug you run!! 2. They are a terrific value....$0.25 cheaper than those crappy NGKs. 3. Someone has invented a machine that allows you to track ignition advance independent of the actual ignition timing position. 4. Something I'd never thought about until now...new plugs give you more HP than old ones!! I was gonna do a whole figuring out the distance light travels in the time it takes for a crank with a (rough) circumference of 565.2MM to move 2 degrees (about 3.14MM) which is .0000000001047391258928 of a second static, but without the RPM, I can't figure out the equation because it MUST be relative to crankshaft speed if it slows the passage of time to allow the spark to reach the tip faster than the speed of light unaided. Since the the speed of light is a constant that doesn't change, it must be due to a shift in relative time. Think Stargate. More RPM = a greater slowing of time, which allows more advance. Therefore, it can't just be a 2 degree advance, because it is obviously variable. Thank you Stephen Hawking for that Brief History Of Time. Now that's funny...all you need is a flux capacitor to complete your theory, you're well on your way... 1.21 Jiggawatts??? Great Scott. Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted August 6, 2007 Report Share Posted August 6, 2007 I am gonna hook a lightening rod to my bike, that way there it will be capable of time travel!! :yelrotflmao: Quote Link to comment Share on other sites More sharing options...
dynodon Posted August 6, 2007 Report Share Posted August 6, 2007 I have stayed out of this thread due to being quite satisfied with my BR9es plugs, But THANKS for the laughs. I havent had that much to laugh about lately :biggrin: Quote Link to comment Share on other sites More sharing options...
fck4strokes Posted August 7, 2007 Report Share Posted August 7, 2007 Can Somebody help me wire this into my banshee? Also how much more horsepwer do think i will gain?? :yelrotflmao: Quote Link to comment Share on other sites More sharing options...
zach45 Posted August 7, 2007 Report Share Posted August 7, 2007 is there a diffrence between br9es and the br8es that i run? Quote Link to comment Share on other sites More sharing options...
jayzx10r Posted August 7, 2007 Report Share Posted August 7, 2007 is there a diffrence between br9es and the br8es that i run? The B8 is one heat range hotter than a B9 series. Quote Link to comment Share on other sites More sharing options...
zach45 Posted August 7, 2007 Report Share Posted August 7, 2007 which is better? or same shit? Quote Link to comment Share on other sites More sharing options...
chevy7398 Posted August 7, 2007 Report Share Posted August 7, 2007 wait wait guys i figured out how these new plugs advance the timing, you ready, ok the plugs have sykik powers, they read the ignition systems mind and fire 2 degrees before the ignition system sends the juice to them! so not only are the mind readers but they must generate there own power, no i can rid off all that stator and coil and wires and all that ignition stuff and save even more wieght, man im gonna be fast!!! Quote Link to comment Share on other sites More sharing options...
racer Posted August 7, 2007 Report Share Posted August 7, 2007 I think the answer hear lies in the unicorn print panties he was wearing during testing. They just make things MAGICAL! Quote Link to comment Share on other sites More sharing options...
FireHead Posted August 7, 2007 Report Share Posted August 7, 2007 wait wait guys i figured out how these new plugs advance the timing, you ready, ok the plugs have sykik powers, they read the ignition systems mind and fire 2 degrees before the ignition system sends the juice to them! so not only are the mind readers but they must generate there own power, no i can rid off all that stator and coil and wires and all that ignition stuff and save even more wieght, man im gonna be fast!!! It would be more believable if you spelled phsyic correctly........................ :biggrin: Quote Link to comment Share on other sites More sharing options...
FireHead Posted August 7, 2007 Report Share Posted August 7, 2007 I think the answer hear lies in the unicorn print panties he was wearing during testing. They just make things MAGICAL! Do we need to talk about the superman underpants you are wearing right now? :biggrin: Quote Link to comment Share on other sites More sharing options...
bonbon Posted August 7, 2007 Report Share Posted August 7, 2007 (edited) It would be more believable if you spelled phsyic correctly........................ :biggrin: haha, do you my psychic? Just thought I would throw that out there......... :biggrin: EDIT: And after correcting firehead, I just realized I put "my" instead of "mean" damnit, so much for that idea lol Edited August 7, 2007 by bonbon Quote Link to comment Share on other sites More sharing options...
MSBansheeDrags Posted August 7, 2007 Report Share Posted August 7, 2007 LMAO....i can't believe i read the whole thing!!!!....dbr :beer: Quote Link to comment Share on other sites More sharing options...
chevrolet banshee Posted August 7, 2007 Report Share Posted August 7, 2007 i think the giy that started this little post is retarded and is macin shit up Quote Link to comment Share on other sites More sharing options...
