98'banshee Posted July 25, 2007 Report Posted July 25, 2007 I found out today that you are not limited to just what the dealer sells at your local yami dealer shop...... I could not find a set there under $20 and im kinda cheep so we went to walmart today and I bought some awsome enduro bicycle grips for only $6. All handlebar grips are the same size so find the ones you like before you buy, plus use some alcohol or hairspray for a little easier instalation. Hope this helps a bit. Quote
KaosBanshee44 Posted July 25, 2007 Report Posted July 25, 2007 alcohol and hairspray is no bueno wrap your bars with a thin layer of electrical take, then fill your grip up halfway with gasoline and sling it out. Right after you sling it out the grip slide it on the bar wait about 5 minutes and you'll never get them off. Quote
dajogejr Posted July 25, 2007 Report Posted July 25, 2007 Spyder grips are the most comfortable grips I've ever used...and they're 12 bucks or so. The best grip glue is 3M weather stripping adhesive, it's nasty and yellow...otherwise known as monkey snot. It's the same stuff as Renthal Grip glue...but 1/4 of the price. You can get a 3 to 5 oz tube for a finski...whereas the Renthal branded stuff is 6 or 7 bucks for 1 or 1.5 ounces. Put a little bead on the inside of the grip, keep turning it as you put in on the bars so the glue evens out....and I promise no slip...let it dry for a couple hours. That shit is amazing!!! Quote
okbeast Posted July 25, 2007 Report Posted July 25, 2007 Spyder grips are the most comfortable grips I've ever used...and they're 12 bucks or so.The best grip glue is 3M weather stripping adhesive, it's nasty and yellow...otherwise known as monkey snot. It's the same stuff as Renthal Grip glue...but 1/4 of the price. You can get a 3 to 5 oz tube for a finski...whereas the Renthal branded stuff is 6 or 7 bucks for 1 or 1.5 ounces. Put a little bead on the inside of the grip, keep turning it as you put in on the bars so the glue evens out....and I promise no slip...let it dry for a couple hours. That shit is amazing!!! Ditto, weather stripping adhesive Quote
FireHead Posted July 25, 2007 Report Posted July 25, 2007 Ditto, weather stripping adhesive + the gas trick..............and you're all set. :geek: Quote
jbooker82 Posted July 26, 2007 Report Posted July 26, 2007 Or just get some gips that have the billit bar end plug that goes through them, and have a little billit aluminum ring that clamps down up by the flange on the grip. ODI Atv Grips LINK Quote
strokerace Posted July 26, 2007 Report Posted July 26, 2007 spray some paint inside of the grip slide on wait a few minutes to dry will never come off Quote
