How to install cool head
I think they go for $225 from NOSS or FAST. Comes with choice of domes and Oring kit.
I'm sure you know to dump the coolant out before attacking the installation.
Used light amounts of grease to seat those rings & make sure cylinder surface is clear from debris.
You can put the spark plugs on the domes and drop them in along with the bottom plate.
[Makes guidance easy.] Remove the plugs and drop the top piece in and start torquing in 5lbs increments.. Go 5,10,15,20. Follow the stud pattern as shown on the stock head!
Is there any mods that come with adding 60 more compression? Just 17 domes and I should be ok?
assuming you arent in desperate need of a rebiuld and have over 100 psi right now, that would give you at least 160 psi and thats means race gas.
