Anybody Ever Try a Projected Tip Spark Plugs?
I was wondering if anybody else has ever tried a Projected Tip Spark Plug.
If you run B8ES the projected tip version would be BP8ES
If you run BR8ES then the projected tip version would be BPR8ES.
Standard plug
I put a set of BP8ES's in my banshee. I gapped the plug to .080 and installed them and rolled the motor over. Took them out and they were still gapped to .080. That way I would know for sure if they would clear the pistons. Reset the gap to .032. Put them in and fired it up. Seems to run good. Could be because I was needing a new set of plugs. I figured that getting the spark a little farther down in the cylinder couldnt hurt. Plus it would up your compression a little because the spark plug would take up a little more room in the combustion chamber. The only down side that I would see is easier fouling since it is down in the cylinder a little more.
josh
