Banshee Pro Flow w/ K&N & Outerwear, Adj. Timing Plate, Noss Reed Spacers
#1. Pro Design Pro Flow with K&N Filter, and K&N PreCharger. Bracket has an oring seal that seals the plate to the air box so no dirt can get inbetween the plate and air box. It allows you to run with no air box lid because the filter clamps to the billit aluminum plate. $45 Shipped.
#2. Adjustable timing stator plate. allows you to adjust from -10deg to +10 deg. Plate is used but looks bran new other than where the bolts tighten down against the plate. $25 shipped
#3. Noss Machine Reed spacers. They are the aluminum spacers. The go inbetween the cylinders and the reeds. I dont need them any more because I now run a different intake. $20 shipped.
You can PM me or Email me at jbooker82@yahoo.com
I accept paypal or US postal money orders.
Thanks for looking.
Here are the pics.
Josh...did I sell you those reed spacers? I can't remember.
Free bump for a good guy and good seller....
These are great prices!!!
Thanks much appreciated. :thumbsup:
I cant remember it was ethire you or DOTD. I remember buying the Short Heat Shield sleeves that cascade sells from you.
Reason I ask is because the corners on the inside are machined down, and you can run these spacers before or after the cage. They have to be ground a little if you're gonna put the spacers in front of the cages on VForce style...which I did for my motor....
But ya don't need spacers for a cub!!!
Good luck.
