wickedshee Posted July 8, 2007 Report Share Posted July 8, 2007 i have an o6 shee with a 7 mm supercub set up with 39 mm pwk airstrikers and need to know what would be best for drag racing this shee i need sprocket recomendations please help me out guys thanks Quote Link to comment Share on other sites More sharing options...
dynodon Posted July 8, 2007 Report Share Posted July 8, 2007 depends on a lot of things, tires, length of swing arm etc. I think I would start with something like a 16/43,or 41 Quote Link to comment Share on other sites More sharing options...
ORNANGE CRUSH Posted July 9, 2007 Report Share Posted July 9, 2007 depends on a lot of things, tires, length of swing arm etc. I think I would start with something like a 16/43,or 41 you should start with a 18/ 39 for 5 speed tranny asphault racing this will get you real close 16 /43 is a good sand gear Quote Link to comment Share on other sites More sharing options...
wickedshee Posted July 9, 2007 Author Report Share Posted July 9, 2007 i have a 1 thru4 overide with bigbore sheerer inframe pipes and 39 pwk lockup i have the motor built already just want to have a good combo with this set up its for now on a stock swing arm i dont race it in the sand plain and simple asphault going up againsta 10 m 68 cub with his 38 mm pwk overide and all what do you gus think the outcome would be Quote Link to comment Share on other sites More sharing options...
ORNANGE CRUSH Posted July 9, 2007 Report Share Posted July 9, 2007 i have a 1 thru4 overide with bigbore sheerer inframe pipes and 39 pwk lockup i have the motor built already just want to have a good combo with this set up its for now on a stock swing arm i dont race it in the sand plain and simple asphault going up againsta 10 m 68 cub with his 38 mm pwk overide and all what do you gus think the outcome would be OK SO ITS A STAND UP BIKE YOU WILL NEED THE 17 /39 AND WITH A 1-4 YOU WILL STILL SHIFT 5TH AND 6TH OR RUN THE 18/ 39 RUN 5 GEARS AND YOU WILL NEED TO RUN SOME GOOD REAR TIRES LIKE HOLESHOTS OR RAZER 2 A STREET TIRE WILL HOOK TO HARD WITH A STOCK SWING ARM Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted July 9, 2007 Report Share Posted July 9, 2007 first, you should use some sort of punctuation in your posts. that will better help people to understand what youre talking about. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted July 9, 2007 Report Share Posted July 9, 2007 So you mean to tell me you forked out the coin for a 7mil super cub and didn't bother getting a longer swingarm, and plan to run asphalt? :shoothead: Quote Link to comment Share on other sites More sharing options...
