dawarriorman Posted July 14, 2007 Report Share Posted July 14, 2007 if the spindle shaft is bent, wouldnt that affect the hub and wheel? Yeah, that would affect them, but it wouldn't add a wobble. The wheel bearings are in the hub, it spins on the spindle. If the spindle is bent, upwards for example (hard to bend the spindle any other way, tie-rods would bend first), then you'll simply end up with additional negative camber on that wheel. Id be willing to bet money its your wheel. Quote Link to comment Share on other sites More sharing options...
FireHead Posted July 16, 2007 Report Share Posted July 16, 2007 The whell might be screwed up, but you should be able to jack the bike up and sin the wheel to check that. On the other hand, something about that upper a-arm doesn't look right. Is the inboard pivot point of the upper a-arm adjustable at all? Quote Link to comment Share on other sites More sharing options...
