jessesdavis Posted June 30, 2007 Report Share Posted June 30, 2007 i know this isn't a banshee but i tried Blasterhq.com but it was sayin it was forbidden. my blaster started fine and ran good all day. my dad took off the air filter cause it was completely gone. well i rode it all day ,even went a little muddin, with the air filter off. at the end of the day the damn thing wouldnt start. i took of the carberator and took it apart and cleaned the whole thing with carb cleaner and even cleaned the jet. i took off the air intake and cleaned all that. i go to kick start it and it won't do anything. if anyone has any idea what it might be please let me know. thanks, jd Quote Link to comment Share on other sites More sharing options...
shee4speed Posted June 30, 2007 Report Share Posted June 30, 2007 Dude,theres definately a problem with riding without your airfilter.Try cleaning the carb again and don't forget the pilot jet. Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted July 1, 2007 Report Share Posted July 1, 2007 Riding an ATV without a filter, is a good way, to ruin a motor. You will be really lucky, if your top end isn't destroyed. I hate to say this, but what you did, was plain stupid. If everything is clean, carb wise, and it still won't start, do a compression check. If it's 100 lbs. or below, then rebuild the top end. Low compression will make them very hard, if not impossible to start. Quote Link to comment Share on other sites More sharing options...
jessesdavis Posted July 1, 2007 Author Report Share Posted July 1, 2007 thanks a lot. my dad didnt tell me the air filter was out of it. how do you go bout checking the compression? Quote Link to comment Share on other sites More sharing options...
96_banshee_96 Posted July 1, 2007 Report Share Posted July 1, 2007 Use a compression tester. Hold the throttle in and kick it untill the needle stops. Quote Link to comment Share on other sites More sharing options...
Jhughes7 Posted July 1, 2007 Report Share Posted July 1, 2007 Went mudding with no air filter, I think I found the problem! Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted July 1, 2007 Report Share Posted July 1, 2007 thanks a lot. my dad didnt tell me the air filter was out of it. how do you go bout checking the compression? Well, that's one reason to check your Blaster over, before riding it, and after riding it. Make sure everything is where it's supposed to be, and working. Quote Link to comment Share on other sites More sharing options...
