How do I tear down shocks
okbeast
I'm not sure if you can get the fronts apart...I'm sure ya can one way or another heh, I haven't looked that close to see if it's a pin or what. The rear you should be able to remove the lower spring retainer; use a spring compressor and slide the lower spring stop deal off (or back off the preload all the way and use some tiedown straps or something to compress the spring enough to remove the retainer).
