Rear shock question
crossfade
I'd probably try it with the preload cranked up and see how it does first, but if ya got the bucks it would be worth a rebuild/revalve, especially if it's an older unit (just had my '96 rear rebuilt this year and it was purty beat).
I don't condone the preload thing, but I would try the shock first before sending it out to see what you think. Atleast if you do have to send it out, you'll be able to see the difference that your hard earned cash got you. :geek:
Congrats on your new purchase...
I come from the point of view that "suspension is everything" so looking at it from my angle, your shock thinks you just gained 70 pounds. That isn't good.
If you just crank your spring to get your "Race Sag" where you want it to to make it usable for riding, you will sacrifice your "Free Sag". You will basically end up with an undersprung, under dampened shock that will get progressively worse because you will have the spring at max preload and the rebound set to max...it will kill the shock oil purdy kwik!!
You can find a good deal on an aftermarket shock that will transform your quad into a controlled, precise carver if you drop a few bucks....
Or you can just go out, have fun and blaze it!!! :thumbsup:
Enjoy....
Jay From SanD.
Well put jayzx750. I would also revalve with a +4 swinger.
i have a TCS re-valved stocker......night and day difference
they set it up as a zero pre load ride height adj. dual rate w/eibach springs
it was most definatly worth the coin to have it done....was like 340.00 i think
Dan
