extended 450 shocks?
qboronyrican
can someone please tell me......if i have extended banshee a-arms, will the yfz 450 shock mod work and/or do i need 450 a-arms and/or do the shocks have to be revalved and/or resprunge for extended a-arms ??????.......sorry if i missed the answer in the threads somewhere
The stock 450 shocks will work with extended Banshee arms. You will have to grind the mounts on the frame at least and maybe the arms, and/or shocks, as well to get them in. You will also have to compress them about an inch to get them in if the arms were made for Banshee length shocks. It has been said that the ball joints will wear out faster because the balljoint travel will max out before the shock, but lots of people run 450 shocks with Banshee arms and I have yet to hear of a balljoint breaking.
ok so the extended a-arms will work but is it better than using stock size 450 a-arms(can these be made to fit)????
someone please......just want to know whats better with the 450 shocks....extended banshee a-arms or a 450 a-arm setup with spindles and hubs and all
There are lots of people using the 450 shocks with Banshee +2 arms, there are also lots of people going with the 450 arms now as well. It all depends on your wallet... if you want the best, go with stuff to fit a Banshee properly. If you wana save some money go with the 450 arms. If you allready have the +2 arms stick with them... if you can afford proper shocks do it... if not go with 450 shocks for now. They are all big improvements over stock.
i have the 450 a arm conversion, it performs great and looks even better. the only problem is your arms get tired after awile. there some major steering, toe in toe out problems, but if we can figure out a cure the set up will be the bomb
