floydfan_90 Posted June 12, 2007 Report Share Posted June 12, 2007 I need alignment specks for a banshee caster, camber, toe and ideal Ackerman angle (toe out on turn). Quote Link to comment Share on other sites More sharing options...
letsgetthisdone Posted June 12, 2007 Report Share Posted June 12, 2007 do you have adjustable a-arms? cuz if you don't, you can only adjust toe-in/out. And ackerman isn't adjustable on the banshee, just to let you know. Quote Link to comment Share on other sites More sharing options...
FireHead Posted June 14, 2007 Report Share Posted June 14, 2007 I need alignment specks for a banshee caster, camber, toe and ideal Ackerman angle (toe out on turn). What are you looking to do here? Caster and Ackerman might be a bit of a challenge for most folks with a normal garage and a basic set of tools. :geek: Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted June 14, 2007 Report Share Posted June 14, 2007 (edited) get your self a meter stick. assuming you have adjustable arms... set your pitch and toe to even front and back some guys run -1 in the front but i like mine even set your caster /camber to be minus one on top so they should be / \ very slightly EDIT: oh the ezest part to messure is from center of tire to center of tire... unless you have an adjustable stick you can run from sidewall to sidewall. Edited June 14, 2007 by Bansh-eman Quote Link to comment Share on other sites More sharing options...
FireHead Posted June 18, 2007 Report Share Posted June 18, 2007 EDIT: oh the ezest part to messure is from center of tire to center of tire... Ezest.........really? That's an awesome new word you invented there. :laugh: Quote Link to comment Share on other sites More sharing options...
