what weight gear oil
My manual for my 03 banshee says 10w30 so I have been running 10w30 golden spectro clutch saver oil in it but a couple other people run straight 80w gear oil in there banshees so am I right by running the 10w30 or do I need to bump up to 80w?Thanks in advance
Bel Ray Gear Saver 80 weight here.
The 2 stroke transmission fluid that says 80 weight isnt thick like you probably thinking. Get you 2 quarts of what ever type of 2 stroke transmission oil. Shake one of them and then shake a quart of 80w-90 gear oil that is made for automobiel rear differentaials. There is a deffinat difference.
i always ran Gearsaver 80w , but now with my override it says to run ATF type F so ill be switching
I have been running Type F ATF for along time now and it seems to do the trick. Older automatic transmission are very similair to the Banshee transmissions with respect to gear and clutch lubrication. I know using ATF sounds like the redneck thing to do, but it makes sense.
Whatever you do, do not use a climbing gear oil in yout Banshee transmission.
