Increasing hauler roll out
MDS2106
What is the most air pressure has anyone used to stretch the diameter on haulers.I gained 4" of roll out by using a 22psi stretch,I didn't want to add much more psi in fear of the tire bursting.I was told i could go 30psi, but to me thats awful lot of air..
Thanks
mark
30psi in the sun. Works perfectly. If it is good direct sunlight and the rubber gets hot you can hear then stretch.
On the 21" haulers mounted on 8" wide rims I started with 67" rollout ,after the 22psi stretch in the sun for two days I am at 71 roll out,I would like to get a little more if possible.I have a buddy that has some of the hard to find 7" wide rims.I was told thats good for another 2" of so I might give them a try.Man I thought the tires were going to bust when I added the 22 psi, 30psi would probably have me shittin in my pants .lol My buddy at the tire center said i could do 25# easy :shrug:
30psi wont do anything bad. I put 45 psi in an Extreme Hauler to set the bead. I had to air it up that much and throw in in the sun to set the bead. 30psi will stretch nice and wont blow up or anything.
  • 3 weeks later...
Contrary to what people believe, with the haulers you get better traction with more air pressure.
that is a VERY generalized statment. i find my self doing it alot and leaving my post open to be smashed :)
however adding pressure is NOT always going to give you better traction. you nailed in with the beginning of your post. its all about the conditions of the sand. temp, depth, moisture, ect.
Bansh-eman,I was letting air out, thinking that more surface area against the sand would give me more traction,Then I read a couple of posts on Planet Sands about adding air in the haulers causes the paddles to be stiffer and not fold over as easily.It really works, even at The Clash of the titans in Sicily Island where the sand is the fluffiest I have ever seen, it picked up the 300' time on my son's bike.
Edited by MDS2106
I just bought some nearly new paddles.
I put 20 PSI in them, left them in the sun all day yesterday...they stretched a couple inches no problem.
Started at 71. At 74 now...
I usually set air pressure by the wheelie factor. If you're getting air...you're getting traction.
But, it's not an exact science...
Air pressure, gearing, clutch weights (lockout) as well as the sand type, condition..etc., they all play a part...
