kylechs04 Posted May 16, 2007 Report Share Posted May 16, 2007 Now i know i need to trim some off of the top shock mount on the frame. But it it seems like it wont be enough. These shock are off an 06 yfz let me know any help would be much appreciated. bottom shock mount top mount whole thing Do you think it will be enough if i trim the top shock mount on the frame? Quote Link to comment Share on other sites More sharing options...
Mullet Man Posted May 16, 2007 Report Share Posted May 16, 2007 (edited) you will need to compress the shock some to get it in there. no big deal. it helps to back the upper spring lock nuts (the 2 large gold rigns on top of the springs) almost all the way off the threads. this will relieve some tension on the spring. might even be able to back them all the way off the threads so there is no tension on the spring. then rethread them on once you have the shock bolted in. and yes, where your marks are drawn on the upper shock mount, should be enuf. IMO when removing material, its best to remove a little at a time and test fit the shock a couple times until you get just the right amount removed. no worries man. your Banshee is just like every other Banshee. Edited May 16, 2007 by Mullet Man Quote Link to comment Share on other sites More sharing options...
FireHead Posted May 16, 2007 Report Share Posted May 16, 2007 you will need to compress the shock some to get it in there. no big deal.it helps to back the upper spring lock nuts (the 2 large gold rigns on top of the springs) almost all the way off the threads. this will relieve some tension on the spring. might even be able to back them all the way off the threads so there is no tension on the spring. then rethread them on once you have the shock bolted in. and yes, where your marks are drawn on the upper shock mount, should be enuf. IMO when removing material, its best to remove a little at a time and test fit the shock a couple times until you get just the right amount removed. no worries man. your Banshee is just like every other Banshee. Word. Grind the upper shock mount a bit and then compress the spring to get the lower mount in and you are good to go. A solid pair of hose clamps make a good redneck spring compressor in this case if you do not have one. I thhink gimmeeabeer has done the vice grip compression method in this case as well. Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted May 16, 2007 Report Share Posted May 16, 2007 Yeah.. just compress the spring and get it in there, here u can see where I shaved my mount. Quote Link to comment Share on other sites More sharing options...
kylechs04 Posted May 16, 2007 Author Report Share Posted May 16, 2007 Yeah.. just compress the spring and get it in there, here u can see where I shaved my mount. What year are your shocks because my Tension for softer and harder is on the inside of the shock? hmm? Thanks a ton i was a little worried but not anymore, appreciate the help fellas!!! Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted May 19, 2007 Report Share Posted May 19, 2007 What year are your shocks because my Tension for softer and harder is on the inside of the shock? hmm? Thanks a ton i was a little worried but not anymore, appreciate the help fellas!!! 04's & you can just turn the mount around no biggie. Did you get them on? Lets see the finished product! Quote Link to comment Share on other sites More sharing options...
kylechs04 Posted May 22, 2007 Author Report Share Posted May 22, 2007 well heres the finised product thanks to BansheeHQ. They fit real snug and reaal close to the back of the top a arm because my a arms are +2 +5/8 , but they look like they will work great and are so much better than stock!!! Thanks Fellas!! Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted May 22, 2007 Report Share Posted May 22, 2007 Looks good to me, just make sure nothing rubs and you're good to go! I can't really tell what that is on the front end? Fyi, black pc on those springs would look kickass fo sho!! Quote Link to comment Share on other sites More sharing options...
SandShots Posted May 22, 2007 Report Share Posted May 22, 2007 Looks good to me, just make sure nothing rubs and you're good to go! I can't really tell what that is on the front end? Fyi, black pc on those springs would look kickass fo sho!! Its an empty box of Patron Gold! Quote Link to comment Share on other sites More sharing options...
Washburn Posted May 22, 2007 Report Share Posted May 22, 2007 Are they the RS A-Arms? Looks good man, Yamaha should have put those shocks on the Banshee in the first place. Quote Link to comment Share on other sites More sharing options...
kylechs04 Posted May 23, 2007 Author Report Share Posted May 23, 2007 Are they the RS A-Arms? no they are Ricky Stator Quote Link to comment Share on other sites More sharing options...
kajones Posted May 23, 2007 Report Share Posted May 23, 2007 (edited) Are they the RS A-Arms? no they are Ricky Stator RS = Ricky Stator ? Edited May 23, 2007 by kajones Quote Link to comment Share on other sites More sharing options...
