sheerider1026 Posted November 6, 2007 Report Share Posted November 6, 2007 ROOST ROCKET I TAKE IT YOU ARE FRIENDS OR SOMETHING WITH THE BOYS AT PRO DESIGN THERE PRODUCTS ARE GOOD BUT FAR FROM THE BEST. JUST SO YOU MIGHT HAVE A CLUE WHAT YOU ARE TALKING ABOUT NEXT TIME WE HAVE NOT HAD A PROBLEM WITH OUR IMPELLERS AT ALL THAT MEANS ZERO DEFECTS WE HAVE SOLD I WOULD GUESS MAYBE 3 TIMES WHAT PRO WHATEVER HAS EVER SOLD. SO IF YOU EVER NEED ANY MORE INFO FEEL FREE TO LET US SET YOU STRAIGHT BEFORE YOU TALK. LATER MODQUAD i have one of your impellers sitting here on my workbench, i built a nice cub motor, the impeller failed after 10 hours of use, filled the tranny full of coolant, and i am damn glad i noticed before cooking the motor, the shaft on the impeller is all grooved up, i used a new seal and bearing when i installed it also,. so if u are so proud of the impeller i would sell this one back to you. Quote Link to comment Share on other sites More sharing options...
Swaie Posted November 7, 2007 Report Share Posted November 7, 2007 So much for that zero defect reputation!!! Quote Link to comment Share on other sites More sharing options...
moneybags Posted November 7, 2007 Report Share Posted November 7, 2007 I have a modquad impeller and a pro desine impeller. The modquad impeller will rub behind the impeller on the clutch cover if it is pushed all the way in. Not 100% positive but I dont think I rember the Pro desine one doing that. Quote Link to comment Share on other sites More sharing options...
brian Posted November 7, 2007 Report Share Posted November 7, 2007 i have one of your impellers sitting here on my workbench, i built a nice cub motor, the impeller failed after 10 hours of use, filled the tranny full of coolant, and i am damn glad i noticed before cooking the motor, the shaft on the impeller is all grooved up, i used a new seal and bearing when i installed it also,. so if u are so proud of the impeller i would sell this one back to you. MODQUAD, Looks like the ball is in your court. Seems to me that you should hook this guy up since you boast about zero defects. I'm sure there are a few others that would just buy another brand rather than complain to you about a small item like that. But you come here making those claims and guys that have had trouble in the past will probably surface. Quote Link to comment Share on other sites More sharing options...
