IMMASANDSLUT Posted May 14, 2007 Report Share Posted May 14, 2007 Just wondering if I needed to put some kind of sealer on the metal gaskets between my case/cylinders and head/cylinders? Thanks Phil Quote Link to comment Share on other sites More sharing options...
wrecker03 Posted May 14, 2007 Report Share Posted May 14, 2007 I asked the same question about a week ago. I'm using Cometic gaskets and I ended up contacting Cometic. They told me that their gaskets are designed to not use any sealant, so that's how I assembled my top end. I think the stock gaskets come with something on them to help seal. Hope this helps. Quote Link to comment Share on other sites More sharing options...
IMMASANDSLUT Posted May 17, 2007 Author Report Share Posted May 17, 2007 I asked the same question about a week ago. I'm using Cometic gaskets and I ended up contacting Cometic. They told me that their gaskets are designed to not use any sealant, so that's how I assembled my top end. I think the stock gaskets come with something on them to help seal. Hope this helps. Although I'm using the Wiseco gasket kitm, I guess I'll leave it the way it is. Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted May 17, 2007 Report Share Posted May 17, 2007 I always put alittle rtv on all my gaskets. To many times has my leak down tester shown a leaky base gasket because there was no sealant on it! Also seen reed gaskets leak without sealer too! Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted May 17, 2007 Report Share Posted May 17, 2007 Although I'm using the Wiseco gasket kitm, I guess I'll leave it the way it is. Wiseco gaskets are cometic gaskets. Quote Link to comment Share on other sites More sharing options...
