flywheel nut
i just installed my case saver and adj. timing plate set at +4. i put the flywheel nut back on with the impact ( low torque gun) and it threaded on what appears to be all of the way(same amount of threads before i removed it). is this correct or did i just screw up?? i'm kinda new to the banshee and don't want to screw it up.. thanks for any help you may have .
I use a flywheel holder and I dont have any problems getting it to 58lbs :shrug:
did you make one or you using the back of the inner hub puller for your clutch? those MP pullersd are shit... they dont fit right in the side of the fly wheel..
edit: if its in the bike... you can put the motor in gear and it should hold it...
Edited by Bansh-eman
The holder is a factory yamaha tool.
